Scott Brady
Founder
jh504 said:And this accounts for for virtually all of the light pick-ups being used out there.
But almost zero of the vehicles on this site, and most OHV sites. The vast majority will be heavier in the rear than the front, or at least balanced 50/50.
That rule only applies to perfectly level ground when the driver is not turning. This is also almost zero percent of the time on a trail.
jh504 said:When weight is shifted like this over an open diff it only helps the open diff gain traction.
That would be true on perfectly level ground. Most climbs are not perfectly level, but have crossed axle holes, rocks, etc. that will cause one tire to exceed the tractive force of the other, sending all of the power to a spinning tire. Again, the front has little effect on a serious climb, maybe 20-30% of the available traction.
jh504 said:When weight is being shifted off of an open diff it causes it to loose traction. I want the front that is going to be loosing traction to spin both tires before I want the back which is gaining traction to spin both tires.
I think you want to re-read the above statement...
In all real-world driving conditions in technical terrain, a rear locker will have better tractive effect in 80% or more of cases. When you consider the effects of weight transfer on climbs, steering, axle strength, etc., there is no advantage to installing a front locking differential before a rear one.
