Locking Air Chuck Recommendations
beef tits
I just take the 3 seconds to screw mine on… but I’m using the $120 napa compressor that coincidentally is the same model morrflate sells for morrmoney.
Used to use the ARB rapid deflator, but I got a set of Staun’s and never looked back.
If you just use the threads the way they’re intended you avoid damage.
  • Like
Reactions: mog
geoffff
I have used a few different versions of twist on tire inflation air chucks and highly recommend this design over any of the other clamp on styles i have used.
https://a.co/d/1tLHmna
Seconded! I used those clip-lock chucks for years, and they were frustrating. Screw-on is much less stress.
I also improved the ergonomics / finger-feel of the above screw-on chucks by wrapping them several times with some self-fusing 3M Scotch Rubber Splicing Tape. The larger diameter and rubber grip feels nice in my fingers.
ButchW
This is my newer favorite.....
It has a nice positive push-on action and only needs the button to release. Flow is as good as anything I have tried. Overall, what I like the most is the small compact size that is barely larger than the npt fitting.
Where did you get those? They look interesting… The link doesn’t work for that item, and looking at a pic at Amazon, it redirects me to the same as your link.. Thanks
Butch
geoffff
These look like the same product, with different branding.
JPT4648
