Lone Peak Overland
BudLoomis
We'll get this baby mounted to my truck tomorrow morning, just making some final adjustments to the rear pop-out load bar. I will also get an interior pic to show how many supports there are for the roof skin. The roof skin is attached with some amazing VHB tape and a solid amount of waterproof, black rivets.
Antwon412
Maybe it’d be cool if we all start chiming in with some specific info.
Order #1294
2022 Jeep Gladiator
Ordered options:
Solar wiring port
Roof vent fan
2 x Grab Handles
LED & 12v lighting
Options I’ll be adding when confirming my order:
Juicebox
Load bars
Side lights
Awning mounts
Roof panel - white side on exterior
V1GiLaNtE
Order #28
2012 Toyota Tundra DC 6.5' Bed
Ordered options:
Solar wiring port (passenger side)
Roof vent fan (rear location)
4 x Grab Handles
LED & 12v lighting
Juicebox (passenger side)
Roof panel - white side facing out
Door panels - black side facing out
I'll add the latch lock pins when I get my install complete. I may also add a molle panel TBD.
I thought about adding the side lights, but I don't like that they become unusable once the door panels are open. I plan to mount some BD S2's just in front of the door panels on the t-track to provide usable light when at camp. I will wire those to a switch inside the cab and will pull power from my engine bay fuse block.
I'll be powering the camper with a Goal Zero 1500x and will add my own Renogy solar panel (175w) later as well.
1titanfan
Ok I’ll bite. Order#1248 and I’ve changed my mind on having the white side out. After seeing the build the amount of surface area left by installing 3-100watt panels is minimal. So 2-grab handles, roof vent, wiring + lights, no windows anywhere, 3-sets of awning mounts, 2-molle panels, juice box, I think that’s it maybe different when I hear the feedback from those who go before me. So when is #002 rolling out. Looking for more pics.
V1GiLaNtE
What changed your mind about white side out? Or were you going to do all panels white side out?
1titanfan
I’ve talked to a lot of people about flexible panels and heat. First, sun and heat kill solar panels, I park my truck under a low carport so it rarely gets any sun or heat. If you look at the post with my truck you will see a 100 watt Renogy ridged panel which worked awesome and after 3+ years it was running at about 75% even in bad weather. I like the black on the outside solely for looks. The white would help with keeping the tent cool. The 3 panels will cover 75% of the roof anyway. So I’ll have 300 watts of solar, a 40amp Epever controller, a 2500 watt Vevor inverter and 2-105ah epoch lifepo batteries(not the same as L/P is offering, but the ones they are offering are excellent).
TexasSixSeven
Order #29
F-250 short bed crew
2 grab handles
Mole panel
High load bars
Vent fan
Gear Vault
Lighting and Juice Box
Heater port
Solar port
Lightbar port
Power Plate w/Invertor
Awning miunt
Ladder
Black side roof out
CharlieGreenT
