rayra
My long-time fav jumper cables have a pitifully small wire gauge. I might need to make a better set. I was trying to gauge the gauge of inserts needed for the Anderson terminal lugs. With the intent of cutting the cables to add a set of plugs about 1' from one end. So I could plug the cables into the bumper connections. But the wire is so pitiful I think I want to use much thicker cable.
Skinny little wire in a fat insulator. False advertising. I was expecting them to be thinner than the insulation suggested, but not this thin. Disappointing.
I was checking the gauge with the intent of getting some reducing bushings to put into the 1/0 lugs for the Anderson connectors.
powerwerx.com
But there's nothing that tiny. Nor do I want anything that small. I can neck down to 4ga. So I'm thinking to just make a new longer set of cables out of 4ga welding cable. <$1.50/ft on Amazon. ...
something to look into after the winch project is wrapped up.
Long been an adjunct to my ideas of having the big power plugs at both front and rear bumper. Part was having cables that plug in at the bumper or some other larger power accessory. Long ago in the Marines the 5-ton trucks had what was termed a 'slave cable', which was in essence a jumper cable that plugged into bumper receptacles, extending the reach. And that idea has always stuck with.
Anderson Power Products Powerpole Reducing Bushings
Optional reducing bushings assure proper fit when crimping contacts to smaller diameter wire sizes. For use with PP75/SB50, PP120/SB120, PP180/SB175 and SB350. Loose Piece.
