OK ,mission accomplished,well sorta. Drilled out the lower ball joint stud,got it to release, but now I cant get the ball joint out of the lower control arm? All 4 bolts holding the ball joint are out,the brake caliper,outer tie rod ,abs sensor are all releases, but there isnt enough wiggle room to remove the ball joint even with half the stud cut off. To me it looks like I have 2 options, remove the hub or the lower control arm? The FSM sucks it dosent state how to tackle this in detail. Its good for torque specs etc..
Help!
Help!
