I'm not sure anybody here has any info on this but thought I'd ask.
I'm beginning to hear a slight click in the front; sounds like a CV may be getting tired. I also have a small leak on one of the boots, so I figure I'll go ahead and do both front half shafts when I do the other work in the front of the truck. Hey, they've got over 120K on what I suspect are the originals and I do use the truck hard, so it just seems like a good idea.
Anybody have a preferred brand/source? AB doesn't list them at all; BPUtah has OEM for $285 and unknown aftermarket for $150; RockAuto has aftermarket stuff from $55 to $85. So we have a rather wide spread of $55 - $285.
While I would much prefer reliability/durability over saving a couple bucks, it's hard to see tossing out nearly $600/pair when I could be spending $150. So, any specific aftermarket brands you'd recommend for or against?
Another thought - does anybody know if the LR4/RRS SC part is a direct fit replacement, and if so, is it notably stronger given the added power of these vehicles? While CVs are not known to be a weak link on the LR3, more beef is always good when you play hard. (note: I believe it is actually the same pn, so no advantage, but thought it worth asking)
