LR3/LR4 REQUIRED UPGRADE: Prevent Rear Door Failure for ~$25
micahd
In my mind this is the definitive post on this important fix and the Google agrees, so I’m adding my comments here. I did this today w the same parts (ordered at least a year ago when I first saw this), but I ended up doing it a bit differently for reasons I’ll describe.
I first attached the recliner handle cable with a small length of very tough wire and some
JB Fast, plus a zip tie. I used the same hole method of attaching the cable housing to the latch assembly. Brilliant move by OP.
I then planned to just disco the handle from the cable and tuck the cable end somewhere easy to reach if I ever needed to. But I couldn’t find a place I liked that wouldn’t be blocked with the door latched*. So I went back to using the handle, but just mounted it through the trim panel rather than into the subwoofer panel, to save all that precision metal cutting. I used a hole saw to cut 2 overlapping holes that fit the oval of the handle “cup,” and it sits in a rectangular opening next to the latch. Pic shows approx placement, and then finished:
I don’t know if this also worked out for the OP, but I love the fact that the handle is covered by the lower panel when the gate is closed. The only thing I don’t love is that something heavy sliding out of the back could damage the handle. Like the 1K lbs of flagstone I moved in it the other day…
*So if I were doing again I’d use a long cable, (through door bottom and into rear floor like the last post indicates) — mounting the handle in the D-pillar. Or just tuck the cable into one of the 2 rear cubbies for emergency access.
Thanks again for the idea, sir!
iowalr4
You can now just "buy the kit" instead.
The LRP kit is pretty nice. Comes with everything you need, the bracket and wire with the connector. I am able to use the lever even with the front runner drawers in place. Just enough room between the face of the drawers and the latch to pull it.
2KewlGypsy
Thank you too the original poster, and all the follow-up. Bought a LR4 this past weekend with 100k miles. Liftgate worked at the dealer, and didn't when I got home. Ordered the part from Amazon using the link and put it in today. Waiting on a new actuator as well, but I can get in and out of the back from inside now. Thanks for the help!
