Lr3 RAI pictures and directions.
vfly172
I purchased a knockoff raised intake. I'm ready to install. Does anyone have a link or the directions for the OEM intake?
I'm also looking for pictures of where it attaches to the pillar. Specifically fitment, does it fit tight against the pillar or is there a gap?
LR4XFAR
SCLR member 2013 LR4 HD
Little gap, but no bad at all. I installed an eBay/China special. No instructions.
Drilling the holes in the fender was easy. Getting the nuts tightened was a chore.
Pull off the black trim to the side of the windshield. Loosely put the bracket on the snorkel for the upper mount and mark the metal A pillar for the rivets. I needed to buy a couple of rivet (steel and long). The steel in the A pillar is really hard! Get a few extra drill bits! Seriously, it took me four bits to drill the holes. You’ll need to trim about 3/8 inch off the trim to allow for the bracket.
Worst issue was the pipe that goes in the fender. I had to cut quite a bit out of the inner fender brace up near the air box. The metal was so sharp and the pipe was sliced up pretty quickly. The one that was shipped to me was about 4-5 inches too short. Sourcing one that worked was a pain.....
Hope this helps. Good luck!
Smudge12
