lwg
For those of you with LR3's that have replaced the factory battery with the Diehard Platinum, which one did you use? The only one I see that is a pretty close fit is the Group 34 or P-1. However there are still a few minor issues with it.
1) Looks like the factory tie down won't work. I'll have to get a regular ol' battery tie down with some longer bolts.
2) Since the positive & negative posts are backwards I have to move both of them further inward, not a problem for the negative terminal however the positive terminal now exposes part of the cable to the engine bay. Do most of you just nip off the rubber gromment and reseat it closer to the battery terminal? I'm worried the plastic from the battery box will eventually wear through this wires insulation if something isn't there.
Basically just wanting to make sure I'm not making this harder than it should be.
BTW, I just checked and they have the Platinums on sale right now, P-1 would normally be $219 is listing as $175 this morning. I'm going to head back in and see about getting a few bucks back when I drop off my core.
