LR3 suspension fault normal mode only
Eric K
So my 06 LR3 is getting a "suspension fault normal mode only" error. The suspension raises up, I got a few miles down the road, then get the error. 4x4 screen isn't telling me anything. When it first started it would only happen on the initial "drive", if I stopped to get a snack, and restarted the vehicle, then I wouldn't get the error. Now, I get the error almost every time. Any thoughts? I've heard old batteries could cause all sorts of errors, mine's a bit old, could that be the cause?
Howski
Yes, a GAP tool will tell you the exact fault and you back hunt down the issue from there. Could be a handful of things so it’s best to fully understand the issue
vertical.dan
