M100 bearing replacement - civilian parts equivalents
rustystruck
I'm trying to determine what civilian parts equivalents that I'd need to replace the bearings in my M100 trailer. So far, I've seen on other boards that I could use front wheel bearings and seal for a 1960 CJ-5. Will the M416 parts work in the M100? I'd seen that the 416 would use Federal Mogul Set A-35, which consists of bearing LM501349, race LM501310, for seals the Federal-Mogul 472018. I also understand that I need a bearing washer, nut, and crimp washer. Any idea of civvy equivalents on these? How many do I need? I realize I need four sets of the bearings and two seals to complete the job. Thanks!
Any auto parts store can set you up with stock bearings and seals. I used something different instead of the old style jamb nut, bending over the washer. Look at the X-lock from Stage 8 D44 type.
taunger
