I picked up this trailer to build my camping rig. It was disassembled, chopped up for the tail gate, longer A frame arms fabricated and extended tube out the back for a rack. The bed was reinforced with two extra cross members. All those parts were galvanized before etching primer, seam sealer and more etching primer and then some paint. The springs have been blasted, painted and reassembled using poly slider material and new hardware. I rifle drilled and relieved the spring/shackle bolts to provide for lubrication. Wiring is almost complete which will be LED and include backup lighting. It has received a SOA conversion on the custom axle I built using RRC rear spindles and hubs. The landing leg has been replaced with the tongue jack. There's still a long way to go as I've barely started the hard top which will include a modified SII roof and RTT. In stock form the trailer sits 42" to the rail but now sits at 49". It will settle a bit more and should be at 47"- 48" when everything is installed.
