loremordred
It's been a while forum.... I've missed you guys.
So I have just buttoned up my 04 Monty.... and I have a problem. Won't start - turns over, but seems to not get any fuel for spark.... It can spark with starter fluid, but once it runs out of fumes, it dies. Any ideas? Maybe the vacum lines are backwards? Is there a fuse that could be blown? spark plugs?
What I did.... I changed the Gaskets on the passenger side Rocker cover/Cam (where the oil leaks), took off the Intake plenum and cleaned it out, cleaned the throttle body, replaced the spark plugs and wires.
The driver side spark plugs when removing them were full of oil.... I don't know if this is supposed to be that way, the passenger side wasn't. I wanted to replace the gasket on the driver side, but time is pressing and I will have to do it later.
After that I tried to do the timing belt, but after taking off all the accessories and the serpentine belt, I could not get the cover plate (Accessory mount) off.... According to the diagram, I had to remove the power steering pump bracket.... but this was impossible... there was no space to remove the bolt or get to the second bolt... I could not see any other means of removing the bracket, or the ac/power steering pumps to get out of the way. The bolt would hit the steering wheel shaft...
I mean, I had all the main bolts out, and the mount would move and wiggle and even shift... but the one bracket wouldn't budge enough to remove it.
So I gave up trying to get the plate off to do the timing belt, and put it all back on, and will do it later or take it to a dealer... if I ever have money.
So once again...
1. The engine wont start, it will crank, but wont ignite. Will ignite with starter fluid, but wont stay on.
2. Now that I reconnected everything and hooked up the battery, my door lights wont come on.... wondering if a fuse blew or its a timing/calibration issue. (may have had a spark jump from the alternator, i forgot I left the battery connected).
It's been about 3 days I've been working on this, I'm tired and can't think straight. So any ideas are welcomed greatly.
So once again...
