Maintennce on a Frontier
AlabamaWill
Ok I have a 2006 Nismo Frontier it has 93761 miles on it, Ive Flushed the trans, changed the rear diff, order new NGK spark plugs anything else?
mcm4090
If you have not already done it I would change the brake fluid. It should be change every 30,000.
I would also change the PCV.
Cypher
Full Time Traveler
Front diff fluid (4x4), coolant flush, power steering flush, and an in-cabin air filter. That is what I would do... :sombrero:
RonapRhys
Bloody 'ell. One of these days I'll get a single fact right. Guess that's what I get for floating around on too many forums...
RonapRhys
There is that, too. Plus, considering that I've not needed to do any of that maintenance (and won't for another 60K miles), I'm probably okay.
AlabamaWill
Ok I just tried to put in new spark plugs made be NGK and the are to small. Even though the part number match what NGK's website says to use. Does anyone know what spark plugs are suppost to be use?
Big Daddy Chia
If they are factory plugs they are probably iridium from denso. Thats what the versa has and I know they have been putting 100k mile plugs in nissans as of late.
WonaWarrior
