Mwilliamshs
I have a Ford 4.9L (300 straight six) and a C6 automatic with 3.08 gears in my van. No issues with the combo at all. Pretty happy with the mileage even.
BUT
I found a great donor van with a 5 speed OD transmission. Factory Ford issue. Same wheelbase, same engine, so driveshafts are correct length. I could swap everything from the bellhousing back, completely bolt-in. Would have to, my gears + OD would suck. The donor should have 3.55s but can't confirm. I'd swap to that ratio either way. The scope of the swap is well within my skillset, tools etc. I'm very comfortable with driving a standard transmission and regardless of what transmission my van has I'm likely to be its only driver, ever.
THUS
I'd gain efficiency. Probably not a lot, but 3 mpg is about what I expect. That's average. Pure highway would probably be more like 5 mpg. I'd gain some novelty, a clutch pedal in a van is rare. I'd lose convenience, can't just put it in D and zone out. I'd lose space. The shifter takes up room in the cabin. I'd gain engine cooling. No more transmission heat in the radiator. I'd gain uh...sweat equity? Knee pain? Wrench time?
SO
What would you do?
BUT
THUS
SO
What would you do?
