Mauka2Makai - Our Quest Begins...An 80 Series Adventure
kletzenklueffer
Welcome to the flareless club. I have my flares (well most of them) and thought about putting them back on, but just don't want to.
As far as rocks and stuff, no issues here. Any rocks I hear thrown hit inside the wheel wells.
r3run33
thanks for the input; mostly I'm concerned with rust eating my poor truck. Here in the northeast they spray that stuff on the roads and it destroys the vehicle. My heat shields have melted away; many of the clamps I have replaced. The exhaust is very rusty etc. Our vehicle hold a high resale value so trade in would be excellent. But I am planning on keeping my 100 series. I will start a tread as soon as work begins.
Mauka2Makai
Flare Removal Update
My original intentions when I pulled my flares were to replace the badly dry rotted flare trim and repaint the flares themselves, I planed to paint them matte black. With the flares off I was able to clean the years of dirt and grime built up that could have led to a corrosion catastrophe in itself. While off a new vision was born for the LC... to have the holes welded and painted for a flush and clean look. After numerous price quotes and the reality that it was more than I was willing to pay at present moment, I explored the different options. I could install original flares with new trim, I could "line" the flare areas, or I could install aftermarket Bushwaker style pocket flares. I am not convinced that the flares provide any other function than an aesthetic value. I'm partial to both the flare and de-flared painted look. So what route did I end up going? Drum roll please... I decided to go with an aftermarket Bushwaker style pocket flares. Why? You may ask. Mainly to keep things fresh... a new look. I'll roll with this until I have the funds one day to have things properly done (holes welded) and the whole vehicle painted.
The Bushwaker style pocket flares are made to order and are made with fiberglass and high quality flexible resin so that they are very durable and flexible. They are repairable or available for individual replacement if damaged beyond repair. They are installed with Torx hardware and come with new trim gaskets, I'll also be able to reinstall the OEM front and rear mud flaps. The flares are currently being made to order at present time and should be door side within 3 weeks.
I'm anxious to see first hand... the build quality, fit, and installation / security of these flares. Stay tuned for their arrival and installation.
HeHe... Trying to keep things fresh. :elkgrin:
Sempertoy
Love the new plan. Those pocket flares sure do look awesome.
The more I think about those pictures of all that yuck under your flares the more I think about pulling mine and lining the whole side...
tazzuk
Awesome thread and cruiser. The pocket flares will look great, imho I've never really liked flareless and the flares do keep mud off the truck and windows.
I did replace my fender trim and cleaned the body while the flares where off, it had a nice build up like yours.
Mauka2Makai
It's been a little over a month with the flares off... I'm really digging the the look just not the holes.
It's a can of worms under the flares.
Thank you... you've got a very nice cruiser by the way.
Mauka2Makai
A few new changes to the LC in the last month... heres a sneak peak.
stioc
Finally an update! but only a teaser :costumed-smiley-007. I like the pocket flares, they give it a tougher and more rugged look.
Mauka2Makai
Looks good with the pocket flares. What meats are those?
Thanks Jon, Cooper St Maxx 285's.
Those flares look good! I can't wait to see all the new changes as I'm sure it will be sweet.:sombrero:
Thanks... I've been fortunate to have been able to find buyers for most of our gear to help finance these new changes to the LC. Slowly it's coming around.
Stay tuned as I'll write up a bit on the installation and thoughts. The flares do change the look of the LC quite a bit, I'm just not sure if this is the final look I'm looking for.
Not a fan of those flairs, but to each there own. Truck overall still looks good great.
Thank you... I appreciate your honesty.
Mauka2Makai
Pocket Flare Install
When I first removed the original OEM flares last thing I thought was that I'd be replacing them with Pocket Flares. Yes, I could have easily reinstalled the OEM flares and repainted them semi gloss black as the pocket flares. With the OEM flares off, I guarantee you, I spent way to much time debating what route to go. Should I reinstall the OEM flares, should I go with lining, should I go with weld and repaint, or should I take a chance and install something new and unique. Ideally I would have liked to have gone with a weld of the flare holes and a fresh repaint of the whole vehicle . My compromise of the situation was to install a set of pocket flares, with the whole idea of reinvigorating the look of the LC... keeping it fresh. As noted earlier the Bushwaker style pocket flares are made to order and are made with fiberglass and high quality flexible resin so that they are very durable and flexible. They are repairable or available for individual replacement if damaged beyond repair. They are installed with Torx hardware and come with new trim gaskets and allow for the reinstallation of the OEM front and rear mud flaps. Around a month and a half later...
The flares arrived packaged well and intact. First thing I noticed was that the insides were unpainted.
Composite fibers when exposed to water can induce a wicking affect that could lead to swelling of the composite material and breakdown of the epoxy.
Flares painted Semi Gloss Black inside and out. Matches ARB bumper finish nicely.
Installation was fairly straight forward:
I measured to find center and predrilled the holes on the flares first. Very important 3/16" only.
Installed the new flare trim. The trim could have been an inch longer for each flare.
Reinstalled the lower rear door brackets with new 1/4"x1/2" rivets.
Rubber bumpers are installed on the rear door lower brackets to provide bump stop for the flares. I installed an additional 1" rubber bushing to provide constant contact with the flare.
Now comes the fun part of aligning the flares to match the OEM flare lines. For the fronts I installed the mud flaps which allowed the rear portion of the pocket flare to sit in and soft secured the forward most screw of flare behind the front bumper wing. This allowed the flare to be leveled and aligned with OEM flare outline. Start drilling from the center and work your way outwards alternating front and back while installing Torx screw at each hole. When tightening the Torx hardware be very careful not to over torque as to avoid stripping the screw or hole. Alternately you could install nuts on the backside or rivnuts which I may do in the future.
For the rear flares I installed the back ones first. I soft installed the screw behind the rear bumper wing and aligned to OEM flare outline. Once again drill 3/16" hole, install Torx screw, and maintain alignment.
The forward rear flare on passenger door had to be held in place while drilling making for a very tense time ensuring alignment. I must have aligned twenty times before my first drill in center position.
Bump stop shown in contact with flare to help maintain position and reduce stress to flare if lower portion bumped.
My greatest suggestions during the installation of these flares is to allow ample time for installation and to not rush. Do not over-torque the Torx screws. Paint the inside portion of flares. Avoid removing screws once installed to prevent cross-threading and stripping of screw holes. Long term solution as in next time they are removed for cleaning (maybe a year or two, hopefully more) I'm thinking of adding nuts to the back end or rivnuts. I'm sure more will come along.
My overall thought of these flares is that they are of good quality. They would be fairly easy to repair. They do provide a unique and distinct look. Long term we'll see how they hold up. :)
