MaxTrax vs Pull-Pal
TexasTJ
Climbing Nerd
I'm looking to start building a better Solo Recovery kit. Right now I'm trying to decide what would be a more useful tool MaxTrax or Pull-pal.
Anyone have any opinion of them. They are about the same cost so right now I'm thinking about utility and weight.
Thanks
Nate
BIGdaddy
if you have a winch, a pullpal is a proven performer. It's heavy, but it's also bombproof.
I've never used a set of maxtrax, but I've watched dozens of vids of heavily bogged vehicles, be successfully recovered. A set of (4) of them carried on a set of thule bars, would weigh very little, and would be a very effective way of recovering one's self.
They, by design, could also be carried easily over to a someone else's vehicle in your convoy and used on their rig, too, without risking putting your truck in a position to get bogged.
There are some situations where a winch would be the best tool for the job (righting an overturned vehicle/moving a vehicle away from a tree it's leaning against/stabilizing a vehicle as it makes a descent/ascent/etc), but honestly, the maxtrax would solve a lot of issues related to lost traction experienced on your average overland/backcountry type off-highway excursion.
Personally, I think a winch, and a set of maxtrax would be the way I'd go. (Granted, I've already got the winch)
The socal deserts and foothills don't have a lot in the way of anchor points, but having carried and used tradtional PSP steel sand ladders for many years, and having seen first hand how effective they are, I think maxtrax is a lighter weight improvement on the older design
AFSOC
I have done it many times in my recovery classes.
Thanks for the feedback Frenchie. I have heard of "bury the spare" for years, yet I've never heard of anyone successfully extracting or even attempting an unstuck using the method. Glad you've tried it and that it is actually a viable option and not just an urban legend.
JIMBO
:sombrero: There's always these-
Course, if your vehicle likes to get stuck :)snorkel:) it's never gonna be easy-
With my tires/gears/driving tech, I don't get stuck in snow/sand anymore, but I have used those Xtracs in snow too-
Mind your "Ps" and "Qs"-
:costumed-smiley-007:bike_rider: JIMBO
temple
I have done it many times in my recovery classes. I personally do not do it outside of the classes. The reason is I have and love my Pull-pal. I do this to demonstrate to clients the proper way to do it as not everyone has a ground anchor. The tire anchor dose have some limits, the digging is a lot harder then the Pull-pal. You need to have the tire at approximately 45 degree, full depth of the tire, and a trench for the cable. The proper attachment to the rim is very important as id the parachute for the winch rope.
This type of recovery the most common problem is the people do not bury the tire full depth and it pulls out the first pull.
Too expand on my earlier post; I do carry the pull-pal for serious off-highway travel and not my general overlanding. The reason is the added weight and I generally know "when to say when" before I get stuck.
And what do you use in a rocky desert, where digging is impossible, and there aren't trees for winching?
JIMBO
:sombrero: A HiLift jack and "push" or "buildup" under tire has gotten me free several times in my desert-
Driving choices/lines will keep you outta trouble too and awareness of throttle !
:costumed-smiley-007:wings: JIMBO
jeremyk
Last summer I was going through the same thought process - what to winch against in the Utah deserts or quick-mud stream crossings with no good anchors. I did my research and ended up with the pull-pal over sand ladders. Buying four ladders or Maxtrax is way more expensive and probably less versatile and if you're in a real bog you can pull out for most of the length of your winch line rather than resetting the ladders.
The Maxtrax seem to be pretty capable, but wow, that's some Ferrari priced plastic! At $75 each, I may have gone that direction but with less versatility in my opinion.
Yuman Desert Rat
I have a couple of options! First the scenario I am picturing in my mind, I have room between the rocks to drive in Re-Bar (with welded washer and mushroomed heads (like a big nail)). I drive in 4 re-bars at locations where I have space between rocks at a sloping angle away from the pull. I then figure-8 rope between all the Re-Bar, attaching the winch to the first Re-Bar. All winch and ropes need to be at ground level.
Frenchie
Seems like a pull pal would be a lot easier.... Just saying....
iStan814
