I'm looking to start building a better Solo Recovery kit. Right now I'm trying to decide what would be a more useful tool MaxTrax or Pull-pal.
Anyone have any opinion of them. They are about the same cost so right now I'm thinking about utility and weight.
Up until a month ago, I would have said no contest for the PullPal. Then we got so buried in a soupy swamp of mud with 400+' to the exit, no chance of winching forward with the first truck and a broken winch on the second truck (motor stopped working), then a broken winch line. The only way we got backed out of there was with the MaxTrax and about four hours of work.
Here is the legend, Kurt Williams (CruiserOutfitters) loading up for the trek into the bog.
The bog
We have used the Maxtrax so many times to literally build roads or exit ramps from nasty ruts, over dunes, etc. We have also used the PullPal several times, so for serious exploration, I really think you need both.
This stuck was legit, with a super slick and crowned track, the heavy Land Cruiser just slid off the road and was instantly buried.
We needed the winch and every MaxTrax we had and a ton of digging to get the truck out. A lot of work, but great memories.
My current approach is to mount four MaxTrax to the spare tire and have them always on the truck, even the vehicle I drive every day.
The tire mount is slick
On our last snow trip, the MaxTrax made for an easy recovery and helped get the heavy Land Rover back on the track
I suppose my final answer would be: When you really need either one, you will really need it, but for most scenarios, the MaxTrax will be more useful and provides some redundancy should the winch stop working. And you can still bury the spare tire, which I try to do only when there are Marines around. . .
