Meet the Trot'n Turtle - Unimog U1300L Build
Questor
Huge member
YES!!!
Looking so good.
The overhead box for the switches came out great.
You may however... need a few more lights.
Nearby planets may not be able to see you.
Q~
Defender
Top work on this build. I've just installed the exact same Pioneer head unit in my Landrover.
A quick question - why is the bus bar up against the speaker?
Hodakaguy
YES!!!
Looking so good.
Q~
Good point, I'll try them out in the dark soon and it they aren't up to the job I'll look for places to add more :)
Hodakaguy
Hodakaguy
That is the ground bus bar...and yeah the holes just happened to line up with the speaker bolts so it was an easy place to land them :)
Hodakaguy
Hodakaguy
Time to get the upper lights wired up.
Setting up the wiring harness for the lights and installing the pins for the electrical connectors.
I used a marine through deck fitting to feed the wiring through the cab and ensure a waterproof seal. The wire is 6 conductor.
Wiring running up to the rack is hidden behind the cover plate along the pillar.
Light!!
Installing a Blue Sea dual USB charger.
Hole drilled in the knee pad under the dash.
And installed
And with the engine cool this morning I decided it was time to check the valve clearance. The intake valves were all good with only a couple slightly snug. Two of the exhaust valves were tight and the rest were right on the money. Good to go for a while now.
More to come soon...
Hodakaguy
Questor
Huge member
Hodakaguy...
You have the best Unimog pRon on the internet.
Thank you for taking the time to document all this.
Q~
Jostt
Very nice job , I would like to ask You one thing, how many km is your engine? Just to has a reference about the valve clearance, beacuse myone has about 70000, I dont have the manual, thanks
Hodakaguy
My truck as 35,000 KM on it right now.
Hodakaguy
Hodakaguy
Up early this morning to get the lights adjusted.
Photo's aren't the best but these babies are BRIGHT! Love the color temperature of the BD Lights, nice daylight color.
Low beam Halogen Headlights
LED Driving Lights mounted on the Push Bar.
LED Windshield Spot Lights
LED Roof Rack Spot Lights
All forward facing LED Lights ON
Side and Rear LED Flood Lighting ON
Hodakaguy
Babbert
