michelin xda 295/60r22.5
steviebam
Would appreciate any feedback on the tires. Intended use is some highway, and FS roads with lots of gravel. They will be mounted on accuride wheels and are going on a dodge 2500 SRW cummins. Thank you.
36.5-37" tires. Will ride very stiff with zero ability to use low pressures offroad, with high load capacity. Designed for motorhomes with ultracompliant suspensions.
I'd RATHER ride on 11.00R16 Michelin XZLs (or even 9.00R16s, AKA 255/100R16s) or if 20s are needed due to brakes, 275/80R20 XZLs.
Charlie
steviebam
Thanks for the input.
I already have the 22.5 rims and adapters so I am stuck with that size. Our camper only weighs about 1300 lbs so weight is not an issue. The truck rides like a tank already, not looking forward to the harder ride.
We will be in the Alaska-Yukon area panning for gold.
vertical.dan
