DavidG
I've been tinkering with a new rainfly solution for my older Mombasa RTT and came up with this...
I'm using some stand-in material (a cheap 12x12 canopy found on clearance) until I can figure out a permanent solution. I know I need to make the rainfly taut, but the pic gets the general point across.
I cobbled together some steel components and had a local guy weld the corner brackets. I'm using a set of modded 4ft long fiberglass chimney sweep extensions I found at Lowes. The poles slide into the brackets and are secured with hair pin cotters.
Definitely low buck
Anyone else come up with an effective solution to replace the small factory rainfly?
Definitely low buck
