Hello All,
So I am new to the Monty world, but excited to have entered into it with a 1998 gen 2.5 (from what I've read). It has the 3.5L V6 and found one with the "cold weather package" that has the factory locker. So I'm excited to have a nice start, but would love to get some input from those more experienced than I. I got this one at a decent price and am looking forward to starting in on a budget build aimed at some camping and overland type adventures as well as a daily driver when needed. So here are my questions based on my observations so far:
1. I suspect quite a bit of oil burning. I can smell it when I get out after parking and my wife mentioned some blue smoke when she followed me home. It has 160K and I know these motors are pretty notorious for burning oil as they age. What should/can I do about this? Or what's the best short term treatment and then long term fix?
2. It drives own the road decent, but it is pretty squishy and bumps are pretty stiff as well as some slight vibration/wiggle at freeway speeds. Just wondered what my most likely culprits are? I am assuming it needs new shocks, but am sure that's not it. Maybe ball joints? torsion bars? springs? not sure what else???
3. What the easiest most cost effective way to get a couple inches of lift? I know I can crank on the torsion bars a little but I think that will only level it out at this point. I'd like to put 33's on it I think. I've read OME springs and torsion in the front but am not sure where to get OME stuff these days. I've also heard I could just use spring spacers in the back and torsion on the front
4. When/if I do lift it a couple inches, will I need to lengthen brake lines on do something about drive shaft angles or bump stops etc.?
5. I was also thinking of doing those 33's on the stock rims and so it would be 33x10.5x15. Will it get really tippy with a narrow and tall stance like that? I know these are a little tippy to begin with simply because of the design
6. I'm not sure what to make of the 4WD indicator lights on the dash. . . they seem to be a little jittery. I obviously don't have any experience with this 4WD system, but it seems really well thought out and very capable. I'm just not sure what lights are supposed to be on when and what it means if they aren't. Sometimes the green wheels light up and sometimes it's just the flashing orange rear diff light in 2WD. I've also not ever had a 4LOW light come on the dash (is there one?) Seems like it would be pretty cool if it all worked and I knew what to make of it as there are a lot of indicator options
7. Usually as I start after starting it I hear what I think is the compressor for the locker pop on really quick for a few seconds and then I don't hear it again. Is that normal? maybe it's just keeping pressure in the system?
8. I'm going to do a full tune up - any suggestions on spark plugs, wires etc.? Combos that work best with the 3.5L for power, fuel economy etc.
Any other suggestions would be absolutely welcomed - trying to put together my priority list and dream list of what aftermarket items and upgrades should come first - my goal is a capable camping and off-road adventuring rig that can still do 70-75 on the freeway as I'd like to take it to Colorado (from AZ) and maybe some Utah trips etc.
Thank you so much for indulging me in this very long introduction and plea for help from those who have gone before me!! Hope you're all having a great weekend!
Matt
Matt
