All-Terrain
No Road Required
Are there any grease points etc that need to be attended to on a Gen 2 Montero SR?
Any other servicing of the drivetrain required?
Thanks!
Thanks!
There are ~ a dozen or more zirk fittings located throughout the undercarriage. It's listed in the FSM.
I was a bit off... There are only 10.
In my 96 FSM it's on page 00-21.
upper a-arm x2
lower ball joint x2
Tie-rod x2
front drive shaft x2
rear drive shaft x2
I make xerox copies to use when I change my oil or give to the oil change place when I have a lube service done.
It can be done on the ground although you may want to drive it up on some ramps (or a curb) up front to get a bit more clearance underneath.
