Monty the 3rd Gen Montero
ChrisCosta416
Super nice build! Following your progress closely as I intend to go King’s by Fall. Your valving/spring rates will likely help Filthy zero right in on what I am after. Thanks for sharing. What are your weights? Can’t read the image.
Hi there! Thanks for the kind words below are the weights
Top is unloaded weight. Bottom is loaded weight with gear for myself and my friend..
Do you have an Instagram?504319
ChrisCosta416
I have installed Kings, if anyone wants to read up on the install and issues I have made a separate thread.
ChrisCosta416
Wired up my Rough country light controller, pretty cheap alternative to the switch pro or s-pod.
I was able to mount it to the 6 disk CD changer location. I used a XLS storage compartment part to use as the mounting location for the switch. I wanted it to look as clean and OEM as possible.
510402510403510404510405510406510407510401
stevet47
I hadn't heard of that light controller before; it looks like a great alternative to the s-pod. At $200, you're right at that point where you can barely DIY a nice system for cheaper. Its a shame all the switches are the same though.
ChrisCosta416
For 200$ I’ll be labeling them myself! Haha
ChrisCosta416
First wheeling trip coming up in 3 weeks, if anyone wants to join us hit me up. We are leaving from SoCal to AZ and then possibly UT
