jingram
... allpar is now reporting:
"While Jeep is still keeping the new interior under wraps, with a promised peek in early July, they did say that hill descent control and cruise control will be standard on the 4x4s, along with steering wheel audio controls. The upcoming Rock-Trac® system for 4x4s uses Dana 44 axles front and rear, with Tru-Lok locking differentials front and rear, and an NV2410R transfer case with 73:1 crawl ratio, electronic sway bar disconnect, and 4:1 gear ratio.
Standard Wrangler 4x4s will get Command-Trac I®, with a neutral setting for towing without uncoupling the driveshafts. The front axle is a Dana 30, the rear axle is a corporate 8.25 axle; a Trac-Lok differential is available."
Clearly some of this is redundant as the Rubi already has the Rock-Trac combo in place. The biggest nugget I saw was the mention of the 8.25 Corporate rear axle on non Rubicon models. Was the cost savings REALLY worth it? You would think that a simplification of their production line would be a better option than bringing in another axle type. Boo Fiat/Chryco... poor choice!
