Here's the story:
Last weekend I had a EAS error light come on and drop me to the bumpstops just as I was coming off the trail. I was able to clear it with the GAP tool but it would come back within a mile or two of driving. I kept seeing the front right sensor go out of range on the in-dash display and figured no big deal, I'll just replace it and be good to go.
This weekend I replaced said sensor (also replaced a broken sway bar end link on the same side) and ... nothing. It behaves OK at parking lot speed but as soon as I get to highway speeds I get the red EAS 'tippy rover' warning light and it dumps me on the stops. I've tried swapping back to the stock rods from my Johnson rods just because, but no effect. Howver, now I'm getting warnings for ALL wheel sensors plus a cross link valve. Clearly these did not all fail at the same time.
I know people often suspect batteries and/or brake light switch whenever odd codes seem to pop up. I ordered a switch last week since they are cheap but of course it hasn't shown up yet (thank you mr. brown). I did pull it and look at the contacts...nothing obvious. The battery has given me no reason to suspect it. I checked the voltage at the terminals this morning after it had sat overnight and had 12.35v. Running at idle I had 14.4v. Both of those numbers look good.
At this point I'm running out of ideas. To make matters worse, I leave for work in the morning and won't be home until Thursday night, then Friday I'm supposed to leave for a club trip I'm leading in the Sierras. Pretty bad when the trail leader has to back out at the last minute!
Any thoughts from the gallery?
