Mounting ARB compressor exposed
vectorsc
I am considering mounting my ARB compressor underneath a skid plate in the front...under the bumper.
It should be fairly sheltered normally, but will definitely be under water when fording such. I actually do this 5+ times a year so its not a moot point.
Thoughts?
4xdog
Maybe call the folks at ARB and see what advice they have? On the face of it, this sounds like a bad idea...
vectorsc
Got ahold of ARB - they said not to let the air intake become submerged - a remote line could be run for the air intake and it would be OK.
ZG
Busy Fly Fishing
That is surprising. I can't imagine it being good for the wiring and solenoids, but if ARB says okay, go for it!
Also, as a side note; ARB tech help is one of the best customer support lines out there from a manufacturer, ever.
xicofixas
if you are thinking about using it as a standalone compressor and not with arb lockers a portable compressor might be a better solution
vectorsc
I wanted it to be permanently mounted to be honest. I like the lesser worries. ... especially forgetting it.
Sent from my SAMSUNG-SM-N900A using Tapatalk
vertical.dan
