multipurpose trailer canopy & roof top tent build
Status
Not open for further replies.
1store
Banned
I been working on my tailgate. Where I got my fiberglass kit .Will lay up the rear skin in my frame.What way the glass will be flat with the face of the 1.5'' angle iron. I can hide the angle are make it stand out. If I first sand with 36 grit on the inside and then pant .That way the fiberglass will be locked in .
1store
Banned
As I am waiting for my tailgate to get back from the fiberglass place. Stared to work on my fenders. There from E-Trailer.com. I made them bolt on .IF I smash one on the trail I can remove easy . I am 225 I got on top no movement .
1store
Banned
Received my tailgate back .Most of the time there's a flat panel there bounded out side are in side a frame behind what the frame is made from. It will be a 1/8''reset .I want to be flat and show the 1.5'' angle iron to show.
[video]http://vid1377.photobucket.com/albums/ah77/sstore1/panalls%20002_zpssg09koq6.mp4[/video]
I'LL ADD SOME 1'' BY 1'' in the back .That way it can be a step for the clamshell tent
1store
Banned
Been thinking I may do a drop down front. I trim the front that all hand laid fiberglass
1store
Banned
After Wednesday it's going to be back in the cold 70. Frame is weld , tailgate made, wood for floor cut, just need to prime and paint.Also waiting on 4 Emergency Rescue Space Thermal Mylar Blankets 84 x 52 to start on clameshell tent.
I was thinking I may try to add some foe rust to the fiberglass.
by dabbing the primer with a brush .
1store
Banned
I've been ask what the back and front panels. look like This kit uses posts that run up from the frame The fiberglass hangs on the post. To me this is the strongest way to go . There is no way for the back to open up. So part of the rear and front is molded to the side panel. In these pictures you see the profile of the tops that I have to chose from . .
1store
Banned
Now that the frame has been sand blasted it should go together fast . Sealed the floor today . Tonight will cut out for the four uprights
I got the tub,chuck wagon & roof top tent kits of E BAY. Under M 100 Series Trailer Tub Kit
If you Email them you can save the eBay fees . It's was over $300 for me.
1store
Banned
Tinkercad Has anyone used it
Just got home from doc. will be laid up for 45 are so days So plan to work on my tent .May try to make it a high rise with slide out.. SO put trailer on hold maybe now that frame is finished . To put on the fiberglass parts of the trailer is to drill 16 holes and tap them with 1/4 20 tap .I going to make this 15 mi seam very hard .So feel sorry for me.
1store
Banned
Today played with the fiberglass rings for the cover. I'll use 1/4" birch plywood for the top center The fiberglass rings stared as High Pressure Aeroponics unit.
1store
Banned
I so want to start and post the Modular fiberglass component hard cover chuck wagon kit Will be using these kits for top and bottom for my tent also .It will make it look like the ALU-CAB tent.When you closed your eyes
Today it was overcast so I could go outside. After looking at the tailgate .It looks as if there was a tailgate in a tailgate.
with the supports tubes . So I am felling in
1store
Banned
I was ask what the bottom look like on the fiberglass component lid . I got it with a 3/8'' lip . Wish I had gone with 1/2'' .A little more rain protection
[/IMG]
1store
Banned
I have changed my plan some .I'll make the cover using the Modular fiberglass component hard cover military trailer parts .
Status
