My 1989 Suburban overland/expedition project
dieselfuel
Hi guys, I'm new here.
Do any of you have a link to a spare tire option that is outside the vehicle? I am upgrading to 255/85's this winter, the spare won't fit inside after that. Plus, I dislike having a 100+lb projectile inside the car, right in back of my head.
Vehicle is '88 V20 w/ barn doors.
Thanks!
the barn doors make it hard, the only rear tire carrier ive ever seen on a barn door sub was a poison spyder type with the fold down carrier. but then you're stepping over/around the tire all the time ad have to lift it back up to close it.
i jumped my old suburban once and had the 36" spare hit a guy in the back upon landing. then i made a strap setup to strap it to the floor pockets for the 3rd seat.
like this.
http://4wheeloffroad.automotive.com/153542/131-1104-april-2011-new-products/photos1-0.html
Erik N
I thought about putting it on the roof, but the fishing areas I wheel into have a lot of low branches. And there is a brush guard up front, so that's out.
These look pretty nice, but I don't have $800 to spend on something like it for a vehicle I use only a few times a year.
http://www.tiregate.com/hg_series_0.shtml
I might just keep the 265/75/16 spare, and hope I never need it. I will be getting E rated tires, so that strategy might work... :rolleyes:
Little Red
Thanks!
Sorry for the late reply. I have been busy using my suburban to explore back roads, go camping and hiking. And I have not really had the time for any mods, so I have not checked the forum in some time. I do have some pictures that I will upload soon.
Now to answer your question, there are a couple options available to mount your spare tire outside. The one I like most is a custom rear bumper with swing out tire carrier like this one:
It is made by Tactical Armor Group link HERE
Another option (and by far the cheapest) is to just use a stock tire carrier from a K5 blazer. I have seen this done before and believe someone else on this forum has a suburban like that.
For now my spare is mounted on my roof rack as I made a sleeping/storage platform in the back of my suburban, and I like having the extra space inside.
zukrider
little red, just went through the thread. looks like you got a real nice truck. especially for such a wet area. as for your plans for the 3-4" lift. if you have not heard of it yet, you can get a 4" lift by moving your 1/2 ton rear springs up front with a little work, new bushings and bolts. the front springs are now 48", and the 1/2 ton rears are 52". you get a much better ride, more flex, and its dirt cheap. this also gives you the chance to upgrade to 56" rear 3/4 ton springs for more load capacity. you will just need the rear shackle flip or to build your own. this is exactly what ill be doing in the next few months, after i fix the head gasket issue.
i like where your going with the build as it is 90% similar to mine!
Little Red
Thanks, and I will be looking forward to see how your cheap lift idea works out.
Little Red
Gas to Diesel engine swap?
After driving on DNR fire roads all night long last week doing a search for a missing hiker with my suburban, I noticed the check engine light came on. The truck runs and drives just fine and there seems to be nothing wrong, I checked the spark plugs, wires and fuel system. All is ok. The light comes on occasionally stays on and then goes off again. I could not find out what is wrong with it until I started noticing a bad smell. I smelled the exhaust and it smells like burned antifreeze.
I also noticed when I filled it up it only got 8mpg compared to the usual 10-11mpg.
I am thinking it might have a leak in the head gasket, and am making an appointment today to have it checked out.
If that is the case I want to see if I can swap the 350 V8 for a 6.2L diesel.
From what I have read online this should be a fairly simple direct swap. Has anyone done this?
xpndbl3
is your coolant level low? Or does your oil look like chocolate milkshake? If not you could just be tossing a EGR code, which happens on older tbi engines.
RADAR12
diesel swap
Love the sub. I did the 6.2 swap on my 90 and i am pleased with the results. I average 18-19 mpg with a combo of city and hwy driving . The swap is basically straight forward if you have a donor vehicle. The little things will wear you out but overall i am pleased. I have a banks turbo kit in the wings that will help out a lot on the power situation. If you need specifics on the swap let me know.
Little Red
Oil is very clean, and coolant level is normal. I did not notice it consuming any coolant either with I would expect if it is burning coolant. (It only has about 40k miles on the rebuilt engine). I am taking it to the shop this week and they will hook it up to their monitor so I will know for sure what’s wrong.
Either way I want to do a diesel swap at some point, as I can get almost twice as many miles per gallon that way. If I am driving it to Alaska next year, that would save me about $1400 in fuel on this trip alone.
However if it can wait I might save some money and buy a Cummins.
I looked around on craigslist and can buy a running 6.2L diesel truck for around $1000
I could use the engine and part out the truck and take the rest to the scrap and probably only be out about $400 to $500. If I where to buy a Cummins it would cost me at least $3000 plus cost for extra parts to make it all work. For that price I can buy a 6.2l diesel, lift kit, winch and winch bumper.
rxm6
I looked around on craigslist and can buy a running 6.2L diesel truck for around $1000 I could use the engine and part out the truck and take the rest to the scrap and probably only be out about $400 to $500.
If you go this route, I will help you part it out :ylsmoke:
Little Red
OK here are some pic's as promised
as I had mentioned before I have not had the time to do any more mods except that I installed 2 more off road lights on the roof rack.
Enjoy the pictures for now...
(yes this picture was taken in early July, we had a lot of late snow here, the summer did not reily start till the last week of July)
