magoh76
Last night I finally found the replacement for my previous Monty that I wrecked two months ago. Drove a few hours to Branson, MO and picked up a 1996 SR with 134k miles. It's got some things to take care of like any 20 year old truck but I think it will be a solid platform for wheeling and family adventures.
I jokingly suggested it's name was Maximus and my wife liked it, so meet Max:
I will be reading up on the forums and Mitsubishi Links to sort out the things below, but if any of you have quick links feel free to let me know:
There are a couple more pics here: https://goo.gl/photos/z2t5DDJvVhYSATbVA
- Rear Window on driver's side doesn't work with button and falls down while driving. Probably fell off the track.
- Smokes a little at start-up. From other threads I've learned this is probably valve seals.
- Get an alignment and check tire balance - there's a little shimmy between 60 and 65 mph.
- Electric door locks are crazy. Unlocks then locks immediately if you don't hold down the button.
- Front wheel lights on the 4wd diagram flash continuously, although the 4wd system works fine. Found a thread with possible solutions to this. PO had electrical tape over the flashing lights.
- Check engine light gives me code for knock sensor.
