My 2001 Pathfinder (R50 ) mild/budget build
FromRaleigh
I like the expanded steel. If you have time, you could even make some panels for the side and rear window and you'll have excellent security, that stuff is tough to get through.
marty1977
That is one great cargo divider. I do have the same problem when stuff slides forward on harder breaking and this really gives me something to think about of doing in the future.
Allof75
Pathfinder
Looks good sir, I especially like the side bars. Any plans to put some holes in there to make a sliding tie down system? Like utili-trak?
stioc
Thanks guys. @FromRaleigh, that's a good idea but I need the room back there- now if I were traveling long distances in questionable areas then for sure :)
@Allof75, that's a great idea, I'll have to look into perhaps mounting the utili-trak to the bars, thanks.
richard310
pew pew
Quite a rigid divider. Looks more like the back of a police cruiser or prisoner transport... :D are you doing vigilante stuff? Hahah
stioc
Another small but a useful addition to me i.e. a way to carry 5gals of water securely. Bulk water is heavy but an absolute necessity and ideally it should be carried low and well centered. In my case I've found the passenger floorboard to be the best place for this 55lbs dead weight except I didn't have a good way to secure it until now.
Allof75
Pathfinder
So that is a water container strapped to what looks like a repurposed child seat anchor? Was the hole already there?
stioc
Correct on the anchor but I had to drill a hole through the floor. I used a large fender washer on the other side for strength and to spread the load. I have been thinking about something like this for a long time but I was overthinking the whole thing. I was going to use the seat mounts holes with angle iron and fabbing up some sort of a bracket similar to the ones commonly available for these 5gal cans etc. Then I saw someone else using a couple of simple D-rings bolted to the floor (on a Jeep) to secure a toolbox - ding ding ding!
I'm still looking for better straps (non ratcheting), light, easy to use, strong and not something that will give or slip :)
stioc
Went to Big Bear this Sat with some ExPo friends. The caravan included:
Two Mitsubishi Monteros on 33" tires, rear lockers and one of them with a lift- both wearing BFG KM2s
One Dodge Power Wagon with 33" BFG KM2s
Two Jeep Wrangers, both BFG ATs, one 33" the other 35"
One Nissan Frontier PROX4 with 32" BFG Rugged Trails
One Nissan Xterra with 32" BFG ATs
My Pathy with skinny 32" BFG ATs
Here're a few action shots of the Pathy.
This three wheeling pic courtesy of nwoods, if I bumped it a bit more it would've been a 2 wheeling pic:
Speaking of flex, how does this look on the rock? I had to drive quite a bit further up to get the rear tire off the ground:
This is after I was already getting off the rock:
As usual there were lots of sharp rocks everywhere on the trail:
End of the day, ready to hit the highway 2hrs home:
AZ_Pathfinder
Awesome pics! That first picture looks like your tire wants to come off the wheel! What PSI do you run when you wheel?
richard310
pew pew
Great pics! You and your Pathy performed flawlessly out there.
AZ_pathfinder: you should have seen his tires rolling through the other obstacles. Tire was near folded in half on the side of a rock heading down the technical section right before lunch.
Psyph
