My 2016 Jeep JKU Build - "Summer Lofn"
FlightMedicJP
Also put my steelies wrapped in nitto's on.
DallasJKU
I had a set on my Jeep and decided to remove them. I also saw rust on the inside bolts, but not too that extreme. I live in Dallas so there should have been none.
FlightMedicJP
I am sure it's worse up here in NY, but there is an obivous design flaw with the pin and the tube being open to the elements. I am replacing the steel pin with a solid stainless pin and welding everything prior to re doing the powder coat. At this point I would not recommend this for anyone to buy until they fix the design. Frustrating, but I need them to get to the rack.
FlightMedicJP
Score a used Rubicon rear axle with 4.10 gears and e locker. Just need to find a front axle. If anyone has any leads I'd appreciate the tip. Thanks!20190808_165519.jpg
DallasJKU
Yeah I wasn’t impressed with the quality either.
FlightMedicJP
Almost done with my Rubicon axle swap to turn my Sahara into a Saharacon., AEV 3.5" lift install and adam's drive shaft install. Finished off the rear end and just a few little items to button up for the front end. I'm loving the look and stance now. removing axles without a lift was not that bad...moving them out of position and back into position was the pain in the ******. Dana 44 with lockers are heavy. lol Also put on new brake pads and rotors.
Dana 44 3.21 rear end out.
No axles
Rear end all done and custom powder coated ARB diff cover.
FlightMedicJP
Finally got out on the beach after all the work.
