cold_n_wet
Cut work today and went to the local chandelry shop.
Found some OK hinges and a possible lock solution.
Expensive lock, but the bees knees.. bit cheaper than Southco.
Ok qualilty hinges.
Trial mounted a door today, happy with the results.
Three hings should hold. I got a new rivnut tool from MEM, great piece of kit. I have rivnuts in the pillar. I will use security bolts when fabrication is finished.
The door is resting on the door seal, good compression = hopefully weatherproof.
Roof bars, ground the welds down today, just a last finish, drill some holes and its off to powder coat
work continues...
Glen
Ok qualilty hinges.
work continues...
Glen
