My Build
05nissanXterra
Make: Nissan
Model: Xterra
Year: 2005
Trim: 4X4 S
Mods:
Suspension:
305/70R16 Goodyear Duratrac's+ spare
305/70R16 BFGoodrich AT's(removed)
285/75R16 BFGoodrich AT (removed)
16x8 MB Black TKO + spare
2" Daystar Spacers (painted to match color theme)
2" Daystar Shackles (painted to match color theme)
Rancho XL 9000 Adjustable Extended Front Shocks (boots to match color theme)
Rancho XL 9000 Adjustable Extended Rear Shocks (boots to match color theme)
Rear swaybar removed
Energy Suspension Front Bumpstops
Custom Rear Bumpstop extensions
Exterior:
Custom Fab'd Rock Sliders
Custom Fab'd 2" reciever
Custom Fab'd Rear Recovery Points
Custom Fab'd Tire Swing on the factory bumper
Custom fab'd front winch bumper
Cuatom Fab'd one piece engine and transmission Skid plate(removed)
Hefty skids plates full set
WeatherTech Window vents
Removed Factory mud flaps
wheel centers painted to match color theme (removed)
(6) roof mounted lights (removed)
(4) 55w speaker 900 lights
Aftermarket fog lights mounted in Factory location(removed)
(6) 55w rock lights
Extended rear differental breather
Extended front differental breather
Extended transmission breather
Melt Mod
Interior:
Custom made ceiling net
1800W power inverter
Exterior to interior AC outlet
Garmin Nuvi 1450T W/ TOPO Maps
Streamlight Flash light Charging base
Fire extuisher
Upgraded FirstAid kit
Survival kit (mounted behind factory FirstAid kit) in a Pelican Case
Extended FirstAid mounting straps
(3) 24gallon Action Packers ( Trail gear/ Camping gear)
Performance:
DynoMax Ultraflo Exhaust Kit
Jet Performace Mass Air
Optima Yellow Top
Optima Battery Mod
Trail Gear:
(2) 3x20 Tow straps
(1) 4x6 Tree Strap
(4) 3/4" shackles
48" HiLift Full set of SnapOn Trail Tools
(3) Craftman Tool Bag
Custom fab'd Slider Adapter
Warn M8000 winch
Future Mods:
Titan swap
Dual Battery
Upgraded rear tie downs
PICTURES TO BE ADDED LATER!!!!
05nissanXterra
Sent from my iPhone4 using Tapatalk
05nissanXterra
Thanks, the pictures don't do it justice on how flexible she is... Let me see if I can find some x rated Picts. Lol
05nissanXterra
I'll have to take a picture for you, on a optima battery the terminals are on the opposite side of the battery compared to the factory setup. So what you have todo is build a short jumper to go from the terminal to the battery mounted fuses.
Smudge12
