Gold Boy
haven said:Kudos to Brent and Jeffrey for spotting these clues about future Fuso products.
x2 thanks
Gold Boy said:is it possible to extend the factory fuel tank for a larger capacity?
duel tanks on both sides or one side?
thanks again fuso fellows!
:26_34_3:
FusoFG said:I mounted another 33 gallon tank on the drivers side. I bought a used fuel tank - might have come from an isuzu - there the same. It came with the j brackets and staps that secure the tank.
I bought the frame stand off brackets from fuso and mounted the tank in a similar location as the stock tank but on the drivers side. I was able to use some existing frame holes and had to drill a couple new ones.
On my 1993 short wheelbase FG I had to move the batteries (mounted 4 optimas inside the camper) but on my 2004 long wheelbase FG there was plenty of room.
I didn't connect them together because I worried about damage to the connecting hose.
I installed two 3 way valves, one for the pick up and one for the return so I could switch them manually.
I added a spdt switch on the fuel gauge sender so I could switch the gauge from tank to tank.
Bajaroad said:Battery question: did you use your camper batteries to start the engine or kept the starter batteries separate?
haven said:Here's one example of a long wheelbase Fuso with a second tank added on the passenger side
The larger tank is the stock 33 gallon tank. The smaller holds 18 gallons. Let's see: 51 gallon capacity * 14 mpg = 714 mile range.
To make room for the second tank, the bands that hold the stock tank were loosened, and the stock tank moved forward. You can see the greyish vertical marks where the bands were originally gripping the tank.
The photo shows the Fuso FG chassis Carl Hunter prepared to receive a Bigfoot 17 foot long travel trailer. After this photo was taken, Carl added a three point mount, with the two fixed points above the rear axle, and a pivot point at the front.
Here are Carl and his wife, Mary, standing with their camper. You can see the aluminum storage box Carl added next to the battery on the driver's side of the Fuso chassis.
Chip Haven
DontPanic42 said:I added an extra tank in the space between the rear of the original tank and the rear wheel. It is 24 " long by 20" diameter vs the 15" diameter of the original tank. The tank was made locally and holds 33 gallons. It gravity feeds into the Mitsu tank. Maybe not as neat and pretty as having everything the same diameter but it doubles my fuel load.
