Count Fred
My FZJ80 - picture heavy, be warned
I've been asked by a number of people to post a build-thread of my rig. I spent some time this weekend cleaning up from the last camping trip and took a bunch of pictures of things I've done.
I'm going to transfer a copy of this write up over to this site, but I first recorded all my thoughts on my own site, so feel free to go here to read as well.
I have a 1994 FZJ80 Toyota Land Cruiser with factory lockers front and rear. Here are related blog entries. My thoughts with any mod are along the lines of long duration expedition travel, keep me safe and alive and get me over or around obstacles, but probably no serious or technical rock-climbing or mud-playing. Probably not fully isolated, but likely single vehicle and I'd like to be self-sufficient for at least 3 days. I will be carrying myself, my wife, and the two dogs, but I'd like to keep the middle row of seat unimpeded to allow me to carry up to 3 passengers when needed. I also do not want to haul a trailer.
[size=+2]Purchased Modifications:[/size]
[size=+2]Built Modifications:[/size]
- ARB Bumper: I've replaced the front bumper with an ARB winch bumper. I've also mounted the AC dryer skid plate made by Slee.
- Roof Top Tent: I removed the factory roof rack and used some spray on bed-liner to cover the stripped paint and partially removed adhesive. I then mounted 4 Thule load bars and placed on them an Autohome Medium Overcamp. This is a longways folding tent which will allow for the potential to carry a kayak next to the tent. Currently, all my stuff fits inside the Cruiser, if more space is needed for storage, I intend to build a half width roof rack to sit next to the tent. I ran power via a trailer hitch connector up through the roof when I filled in the holes from the factory rack. Eventually I will mount lights inside the tent, and or provide a 12V outlet for other accessories up there.
- Toyo M55: Tall and skinny tires, 255-85/16. No fat mud boggers for me. Also installed with the tires is a yellow-box speedo adjuster to account for the 1" change in tire diameter.
- Battery: Sears Platinum Group 31M battery. Just barely fit in the stock spot, but went right in and performs great running my accessories.
- ARB Fridge: 33Qt ARB Fridge, I ran a dedicated outlet back to the fridge and put a fuse box in the back as well for future modifications.
- George's Task LED: I won a Christmas raffle and scored a pair of LED replacements for the door activated overhead lights. I still need to replace the map light with an LED. It looks very wrong with the color temperature between the lights being so different.
- CDL Switch & 7-pin mod: Now the center differential locker can be engaged in 4-high or 4-low. I often engage this on-dirt roads in order to disable ABS.
- Cargo Unit: The cargo unit is constructed in 4 pieces. Two base units, one on either side, a top unit solid all the way across with folding wings for access to the edges, and a drawer to hold the fridge. It was all made from cheap 1/2 plywood, the top was then carpeted and the bottom pieces painted grey and later painted with plasti-dip.This is how the cargo unit is setup, standing at the rear looking towards the front of the vehicle. Here it is all assembled and placed in the vehicle. The fridge is on the left and slides right out as shown below. The Hi-lift jack mounts to the very front of the unit. The red wire across the rear is there to strap the dog's harnesses to, to keep them secure. The top piece is secured to the base units with a hold down at each corner, the base is then secured to the vehicle using the third row seat bolt holes.
Inside the cargo unit fit these four rectangular bags. One for me, one for my wife, one for the dogs, and one for spare parts. Although I currently use one of the bags for parts and my recovery gear, I often carry them in the wings of the cargo unit. This allows access from the middle seats, from the rear windows, and from the rear with only the rear hatch up. I do not want to get stuck and not be able to reach my recovery gear.
