My Gen II.5 Montero, Rocinante
poodwaddle
Following in the footsteps of Steinbeck, I am naming my truck Rocinante (after the horse of Don Quixote). Rocinante is a 1998 Montero that has seen a few abusive owners. He needed a lot of work and I am discovering even more as the days pass. I took him on a ride around the U.S. (following much the same path as Steinbeck in Travels With Charlie) and he performed marvelously. I learned to love even his little eccentricities. He is an old horse, set in his ways. I noticed that the Monte Gen II and Gen II.5 have become rare vehicles throughout the U.S. but when I crossed south into Tijuana I see quite a few of them. They appear to be a popular export, and I suspect that finding parts in junkyards might be a bit easier here.
My only complaint was a terrible turning radius. About a week ago I discovered that some former owner or inept mechanic had replaced Rocinante's steering box with one from a Montero Sport. The Sport has a steering box with a three bolt pattern and the Montero has 4. Realizing that he had the wrong box he apparently decided to drill a diagonal hole into the frame and tap a bolt into it. This gave out on me and my steering went to heck as the box wiggled under any bump in the road (amazing that the whole thing didn't break and cause an accident). I am no mechanic but it wasn't a hard fix. Even without speaking much Spanish I found a junkyard with a Monte steering box and swapped it out. Not only did this fix the problem with the steering wiggle, it also gave me a much better turning radius.
I have not done much else mechanically to the vehicle. Just new tires, alignment, and standard maintenance. He burns a bit of oil and I suspect valve guides. I would like to have the whole engine rebuilt but I don't trust Mexican mechanics so I will probably go to Texas or Arizona and find someone competent there. Just looking at the engine tells me that it isn't a job for an untrained handyman like myself. If anyone here knows of a good mechanic in the south I would certainly appreciate the advice. After that and a few other adjustments are made I will take him on a trip down south into Central America, and if I live through that then who knows where to next.
I recently did a little paint job. I went nuts and painted the lower trim with bed liner. I love the look. Now I just need the red repainted. I really should have had that done first since masking on it will be impossible. Oh well. At least I plan to go with the same color so it isn't essential that the painter mask right to the edge.
I would like to squeeze a few more horseys out of... um... my horse. Any suggestions? I am considering a performance exhaust system and perhaps intake system. Has anyone tried these and can say if they make a difference? Since my vehicle is made for expeditions south of the border I am even considering removal of the cat (mine is a Cali model with the extra HP robbing stuff). Can anyone say if this makes a difference on a Monte and if performance cats do the job? Also I am curious how the Monte's sensors will handle a new exhaust system. For intake I am not convinced. I have seen the typical high performance air intakes under the hoods of teenager's Hondas. The look is just not what I am after. I want real performance, not some silly chrome parts to impress my friends. Does anyone have a short list of possible HP improving mods? I suppose manual hubs are even helpful to some small degree. What do you veteran Monte drivers say?
poodwaddle
Rocinante crossing America.
Clem
I can't speak to any of the mods you mentioned (my Monty is still stock), bet welcome! :sombrero:
Clem
jeep-N-montero
There are no aftermarket exhaust systems for sale here in the states, but any exhaust shop can build you one. I'll be building one for my 98 soon but have some experience doing this and takes a lot of patience. As for air intakes, aside from a snorkel you will find very few if any aftermarket air intakes that actually pull cooler air in from the outside of the vehicle. You could measure your stock filter and search for a dry-flow from AEM or other suppliers, but I haven't seen a direct part number yet for a dry-flow and will not use a k&n with all the fine dust particles we have here. Many tests praise the simple drop in Wix air filter you can buy at any Napa.
MARKSMONTE
EXPLORER
I like the black. nice touch. I have a 99 same color as stock with 31's on it. It looks like you have 33's , thats a much better look.
Sabre
Overlanding Nurse
You could certainly open up the exhaust a bit, but honestly...there just aren't any more ponies in Rocinante. Pero es un caballo bien guapo!
mapper
Nice vehicle and references.
Looks like you were running highway tires on your cross country trip. How are feeling about the change to BFGs? Looks like 33x10.5? Looks good with the bedliner.
Smudge12
