My M416
kai38
I've been towing this M416 for ten years. First behind a '84 FJ60,'95 FZJ80 a '06 4 dr Tacoma, & now a '07 FJ Cruiser. Its been a great gadget to have, When I bought it ($375.00) it was desert camo, I tried to sand blast it, it didn't do any thing to it. I bought some of the best chemical paint stripper I could buy and it still didn't do a thing to remove the paint. I took a cheap grinder to it and I'm sure I inhaled too much of the chemical resistant paint, so I just did an urban camo paint job on it. Easy to touch up just get the rattle cans out and paint.
It has a RTT mounted on it, tailgate cut into it. Did a spring over one day when I was bored. This week I finally got around to mounting ammo cans on the side.
Here are a few pictures:
Outside Jackson WY. during a 2 week road trip.
After the spring over comparing height to FZJ80 Land Cruiser
After spring over
4th of July 2003
Before the spring over I expermentated by placing coil springs between frame & leaf springs.
New storage boxes added this week
Swing down bracket
Camping at City of Rocks NM
Spring over pt 1 http://www.pbase.com/kai38/spring_over_m416_trailer
pt 2 http://www.pbase.com/kai38/spring_over_part_2&page=all
How well did the suspension do with the coil springs before the spring over? Did you notice a big difference? Nice trailer!
Its been 4 yrs since I had those springs underneath. They helped with the load in the trailer, really didn't see much change off road or towing down the road.
I think I bought them from JC Whitney for something else and squeezed them into the trailer just because I had them.
How did you mount the tent and is it stable when you are in it?[/QUOT
I used a 2x2 angle iron bolted to the edge of the trailer, on top of that I bolted a 2x2 square with the top part of a Yakima 1A tower mounted to it. The Yakima cross bars are then mounted through the 1A mounts.
The tent sits on top of the cross bars and are held on at 4 points with 2 bolts each with flat plates inside and the flat plates used underneath bent & curved to the round cross bar when I tighten them down. The plates are like this but used with bolts not u-bolts, that way they lay flat underneath the matteres.
The cross bars are longer on the side where the tent flips open to help support the open 1/2 of the tent. That & the ladder make it very stable.
The trailer is stable, I use to sleep with my 2 kids in there when they were smaller. I always worried about it tipping backwards but it never has. I set the brake and put wheel chocks in front & back of the tires also.
Which RTT is that? It looks like it about covers the whole trailer bed nicely. Are those mil. boxes 20mm ammo cans? Very functional and rugged...
I like it!
Cheers!
I like it!
Cheers!
I bought the tent from Safari Trailers (out of business now) & its has a label sewn on that says Bedouin Tent. It looks like others on the market so I think it was just relabeled. I think they are 2mm boxes I'm picking the trailer up in 1/ hr I need to paint it I'll post new pictures this evening.
Great looking trailer! What tires are you using? Are you using them as tubeless? I'm looking to change out the stock tires on my M416 but don't want to switch wheels right now.
I'll have to go look at the tires I'm not sure the brand or size, I remember they came from Discount Tires. They are tubeless.
Dynamo TCX
