way to much compound to really read the pattern.
what is that lithium grease?
go to a GM dealer and get the yellow GM stuff it will be way easier to read.
I'm going to overhaul a Salisbury axle I just bought for my 109. The diff seems OK by hand, but I haven't opened it up yet. If the play between the pinion and crown wheel is excessive, but the pinion bearings are fine, can I just shim the diff carrier across to engage more tightly on the pinion and leave the pinion itself well alone, or will that need shimming too?
In my opinion, that's just a band aid, and a somewhat ineffective one at that. I would replace the pinion bearings and seal while you're in there and then see what the pattern is like. Better to do it now than to have to break open the axle later.
I used Billavista's write up: http://www.pirate4x4.com/tech/billavista/Gear_Setup/Mercedesrover said:Pinion looks too close to me.
There is a really good instructional .PDF on Yukon Gear's site.
However, the Yukon one states that since this is a used gear set, I should be paying attention to the coast side only. Would you concur?
That's because the coast side is usually in far better (less worn) condition to read. Yukon, if they didn't already, should suggest that you still take a pre-teardown pattern reading on the coast side and match it upon reassembly.
