My summer project (haha) e350 van build
deezdrama
Feeling under the weather but managed to get the driver side insulated and ready for the panels.
Spent the whole day pushing insulation up the pillar ribs and in the cieling ribs.
Didnt have anymore spray foam so made do with the roll insulation, just took forever.
deezdrama
Have not updated in a while.
Got my walls done and need to install the ceiling next.
Got my hammock today and did a test run in it. Very comfortable. I found a 10'6" long double nest hammock which is a little longer than a usual sized one. It worked out great! Laying at a diagonal ...your body stays pretty much flat and felt like I could fall asleep easy.
deezdrama
Thanks!...Its just indoor/outdoor carpet from menards.
The cheap stuff but used it before on a boat and it held up well so figured it should be fine inside a van.
VOODOO7.3
deez, You are making great progress on your van. Looking good with all the metal covered up! That will keep it much cooler in summer and warmer in winter.
Goldenbora
