You have my gears turning. I'm thinking of a steel plate welded to a piano hinge on the tool box. Then use a simple tailgate like strap to hold it up and a clip to hold it folded up.Gear said:Just a thought if you were to raise the Delta box up 3/4" on some sort of rails perpendicular to the side of the trailer. You could slide a piece of plywood under the box acting like a wedge for the table that sticks out. Well hopefully you get the idea.
