Imajeepnut
I have the AT combo slide and National Luna base plate with fridge. How is everyone securing the base plate to the combo slide? I have drilled the holes in the top of the slide, and I have just enough room to put a bolt in from the bottom and a nut on the top side of the base plate. If I drop the bolt in from the top and put the nut on the bottom, it looks like I would have to notch the partner stove slightly to clear the nut.
Is there a better way to do this or will I have to put the bolt in from beneath the base plate? Any help is appreciated!
Thanks,
Jeff
Thanks,
Jeff
