Jim K in PA
We got our RTT from Main Line Overland yesterday :wings: and are now moving toward the design/build of the roof rack to mount it on our 2005 LJ Rubicon. For a plethora of reasons, I am not interested in any of the aftermarket roof racks. This custom rack will have three down tubes per side. The tubes will mount to the body tub at two points per tube. The body tub is being reinforced with 3/16" steel plate at all the mounting points. The entire rack will be removable from the vehicle. I do not want to rely solely on the shear strength of bolts for the vertical load, and am looking for a bracket design that will utilize a mating design to transfer the load to the body, and bolts to join the brackets to each other. Land Rover racks use a somewhat similar design to what I do NOT want:
I have a couple of designs in mind, but both have drawbacks. One will have stand-off type brackets akin to a body to frame mount, with a pair of bolts to clamp them together. However, when the rack is removed, the fixed side on the body tub will protrude approximately 2.5" from the surface. This is not the end of the world, but they certainly present snag points. The other alternative utilizes a pair of reversed beveled plates for vertical load support. This produces a nice, almost flush mount profile on the vehicle with the rack removed, but requires that the retention bolts pass through the tub wall. Captured nuts on the inside of the tub invite thread damage and potentially sheared bolt that would have to be removed (with great difficulty).
Has anyone utilized a low profile design for mounting an exo-cage or roof rack that does not rely on fasteners in shear and is low profile?
I figured I would throw this out and see if anyone has any idea of what I am babbling on about.
