Need Help With Set Up/Needs
aquawolfe
I use my truck for daily driver/towing/hunting/camping/traveling. I want a CB or HAM. I work for the fire dept and we use 800mhz. Can I scan those channels? Also for long out back stuff I would like to be able to send emergency traffic when out of cell phone range. I am looking at Kennwood 71A. Will this be able to communicate with Garmin Hand Helds such as 530/520 or will I have to use a CB? If CB what model do you guys recommend? Sorry for so many questions but I am comfused on what I need. I can get a HAM license if needed. I just want the best set up using one radio.
w squared
It sounds like a HAM would do most of what you want. If you want to scan channels in the 800mhz range, then you will want a dual-band UHF/VHF rig.
This will also allow you to use local repeaters, giving you far better coverage than a CB.
HAM radios will not generally be able to communicate with FRS/GMRS radios unless you perform modifications to the HAM. It is illegal to transmit on those channels unless you are involved in a distress/emergency situation.
PhulesAU
NO 800 mhz. with a HF rig you would be able to monitor CB, talking on it would be a No-No. As would be frs/gmrs.
aquawolfe
So if I use my Garmin I'm limited to range. So I need a Ham radio for emergencies and a good CB gmrs and communicating to others on Garmin radios. Is that what I'm looking at?
gary in ohio
Might be some confustion and to WHAT your garmin is, Garmin has a 520/830 GPS and a Garmin Rino 520 and 530 GMRS/FRS and GPS 2 way radio. I assume your referring to the Rino radio's. Those are GMRS and require a licnese to use on most of the channels. They will not talk to CB or ham radios, They are different radio services. I dont think the Rino's have NEMA output so you not going to beable to link the GPS to the ham radio.
I think we need to step back and define your needs. Long range, short range mean nothing without a scale. What do you consider long haul, what is short.
The Kenwood TM-V71A is a dualband VHF (2 meters) and UHF (70cm) radio. It will require at least a technician license to operate. Range will depend on many factors, mobile to mobile 10-20 miles, longer range is possible with repeaters (repeats your radio signal from a high location with more power than your mobile).
taunger
