Need Jerry can mounting help.
flyingwil
slooowr6 said:
Sweeeeeettttt, What's holding the can at the bottom? Or it's meant to mount in the truck bed or roof top basket?
You would use an L bracket... We will probably have them up for sale in the next week or two, with an estimated delivery of 3 weeks (from now)...
Here is the directions.
1. The two pieces of the clamp must be mounted with each side facing as illustrated and with the arrows on each base facing each other. Use four #10 bolts or screws and appropriate size washers to fasten each base. Do not over tighten.
2. If you are mounting a container, make sure the bottom is on a floor, deck or shelf. Alternatively, support it with a piece of angle iron or wood block (see illustration). This makes it easier to tighten the straps with two hands.
3. Mount the base so that the strap is parallel to the outside edge of whatever you are holding.
4. The “ladder” half of the clamp can be stretched up to about an inch by pulling on the strap (NOT the ladder “steps” or cross pieces) in several places along its length.
5. If you are holding a cylinder, tighten by putting the “jaw” half through the tightest “ladder” section and then pull the two halves in opposing directions. If your tightening a rectangular piece of equipment, you need to push the “ladder” half as far as possible while keeping the “jaw”section flat.
Colorado Ron
Are those straps rubber or silicone base? How well they hold up to extreme weather? Think they will become brittle in extreme cold?
Schattenjager
If they are like the QuickFist material they will be bomb proof. I am really impressed with their gear.
:REExeSquatsHL1:
flyingwil
They are made of the same heavy duty transportation grade rubber that the QuickFists are made of. They are not affected by hot or cold climates or salt. The rubber is uv resistant.
4xCoffee
