Dusty T.
Well, my aux battery setup is up and running- writeup and more pics to follow
The aux battery is located in the front passenger side of the bed. Finding a good place to route the #2 AWG positive cable up and out of the way was a bit of a challenge with the boxed frame and all. Now I'm having second thoughts about how much space I have between the cable and bottom of the cab. I keep hearing about how flexy Tacoma frames can be, and was wondering how much I can expect the cab to move and if I'm at a risk of pinching this cable.
Here's where the cable exits from underneath the cab:
Where the cable travels over the center support bearing crossmember:
Behind the factory harness forward of center support bearing crossmember:
So there's about 3/8" to 1/2" of clearance between the cable and cab at these locations. The body bushings look pretty tight with very little rubber space between the body and frame mounts.
Looked at other options and this looked like the next best one:
This looks a bit more exposed to road debris and heat from the exhaust, but there wouldn't be any clearance issues between the body and cab. Any other ideas, or is this good as-is?
Thanks for the help- this has been an incredible source for technical information on dual/aux batteries!
