Systems:
For electrical, I've selected two 200A/h LifePO4 batteries from
LifeBlue and I left an open space for a 3rd battery in the unlikely event that 400A/h (5.2kWh) isn't enough. I chose these batteries based on their size, reasonable cost, excellent build quality, and the fact that they have Bluetooth integrated into the BMS in each enclosure... there's a handy LifeBlue app so I can monitor each battery (& cell) individually if I ever need to. There's 940 Watts (4 x 235W) of Sharp solar panels going up on the roof which will feed the batteries through a
Victron SmartSolar MPPT 150/85-Tr. The inverter/charger is a
Victron MultiPlus 12/3000/120-50 120V, and for charging from the alternator while driving I'm using a
Victron Orion-Tr Smart 12/12-30 DC-DC Charger. All that stuff was purchased from the helpful folks at
AM Solar. There's no plan for an onboard generator... other than the solar and alternator.
For systems monitoring I have selected a
Simarine Pico display as well several of as their modules (SC501, ST107, SCQ25, & SCQ25T). This will track battery SOC, detailed power generation/consumption, tank levels (fresh, grey, & LPG sensors are from
Safiery), temperatures (indoor, outdoor, fridge, freezer, hot water, & batt'), as well as remote monitoring and some handy programmable alarm functions.
For cabin heating I'm using a
Planar diesel furnace with an analog thermostatic controller. Cooling is via a 6000Btu window air conditioner. In my preliminary A/C test I measured ~425W draw (31A @13.7Vdc. Mfr's claimed EER is 12.1). So as long as there is sun on the panels the solar should have no problem keeping up. For ventilation there will be a pair of
MaxxFan Deluxe vent/fans.
Hot water is from a
Elgena Nautic Compact Air water boiler that is heated by the diesel furnace and/or integrated 120V/500W & 12V/150W electric heating elements.
There will be a 32"x32" wet shower/bath with a small sink, and the toilet is an
AirHead poop-dryer
. I am trying to figure out a simple urinal setup for us guys (standing up at the AirHead is a no-no). The fresh water tank is 50 gallons (420lbs whew! I suspect I may not ever fill it) and the grey tank is 25 gal. Drinking water filtration is through particulate & carbon block filters, and a UV sterilizer.
In the galley, there will be a full size sink, convection/microwave, 2-burner LP cooktop, single burner induction cooktop, and a LP wall-oven. I'm still undecided about which fridge/freezer to get, but it'll be an upright 12V Danfoss compressor type... maybe Isotherm or Vitrifrigo.
On-edit: Changed name and hyperlink to the correct Victron Orion DC-DC charger
