New kid on the block. :)
Michael Brown
You followed me, so now we're both lost
Grab digital copies of the FSMs from my link below. They will come in more handy than the owner's manual. The XLS is a very solid and rugged vehicle. Take due care of the engine and it should last a while. Mine was still going strong at 175k when it was wrecked. Current one is just reaching that mark now.
RyanY
It sounds like you're probably aware, but the most likely reason for the blown head gasket is overheating, which is usually caused by poor cooling system maintenance. The best money you can put into making your Montero reliable is to go through the cooling system completely - if there is any sign of rust in the system do a Thermocure treatment on it, then flush it out several times. Remove the radiator and flush it out several times, replace all the hoses (radiator, throttle body, heater, etc), thermostat and radiator cap (use OEM for the stat and cap). Check your fan clutch and auxiliary fan for proper operation. I'm assuming you'll be replacing all the timing belt/water pump service components (using only an OEM water pump and tensioner) while the head is off, and it would be a good idea to replace the o-rings and gaskets in the coolant pipes as well.
Se7en62
Adventure Seeker
Welcome to ExPo, Wrench. Swing by the house sometime and we can catch up and talk Montero stuff.
iStan814
