New rig....need advise on outfitting
Ducky's Dad
What size tires could I fit if 18 inch rim?
Depends on the rim width, backspacing and offset. You'll need to do some figuring and measuring, with front wheels turned, stuffed and loaded. Rears are generally not a problem, but double check after you figure out the fronts. You are probably safe with 33's, but not all 33s are the same, depends on brand, P-metric vs LT, tread pattern, etc.
rayra
Real nice looking truck.
At that ride height my serious answer is mudflaps. Or some of that polymer clear rock-guard stuff. Especially traveling a lot of miles on dirt / gravel roads. Years in the high CA deserts pretty much rock-blasted the rear wheel-well / fender areas on my C-10
mlmeans
Ty. I really like the rig so far. Yesterday ordered roof rack stuff and air bag compressor/tank. I'm searching for best wheel tire set up. Leaning towards be Goodrich all terrain
