Congratulations on the new treads
Did you find a local shop with the KM2s in stock? The 255s have been on national back order.
Redline
Redline, does the National back order apply to Canada? That's where he hangs his hat.
No back order in Canuck land,
Noise wise i don't see any difference but i am not a good reference, the truck is diesel and my tranny does whine. I haven't check the pressure but they may have put too much in it like all tire shop does when installing new tires. But it felt a bit firmer.
But when you look at the truck i feel like i'm running narrower tires now.
Don't know how much weight i'll check, i always ask to have the weight installed on the inside of the rims,
You say you got new tires but my eyes keep saying BUMPER!
If it gets to be too annoying, you might consider 15s with 33x10.5s. Load range C generally I think? Es are better suited for wagons.. which will weigh between 5000-6500lbs depending on accessories and gear load. Your 42 is probably in the 4000-4500 range?
Eric,
Great looking rig.
Where did you find the tires in Canada - they seem to be hard to locate in that size
